Newbie_1
Execute Data Filter, then close it.
Well, this has probably been answered a million times, but I cant find what I'm looking for exactly, so I thought I would ask...
Here is a JMP Script for a Data Table I am using.
Current Data Table() << Data Filter(
	Location({751, 160}),
	Show Histograms and Bars(0),
	Mode(Show(1), Include(1)),
	Add Filter(columns(:GUN), Where(:GUN == "D"))
Edit (jthi): added jsl formatting
After it executes, what command do I use to close the filter window? It has served its purpose. Now I want to close it automatically, without having to use mouse clicks.  Any help will be appreciated.
Re: Execute Data Filter, then close it.
There is not a need to use the Data Filter to do the exclusion and selection.  Here is a simple piece of JSL that will do the same thing as what you are doing using the Data Filter
dt=current data table();
dt << select where(:GUN != "D");
dt << exclude(1);
dt << invert row selection;
Also, to make your JSL examples you display in your discussion, please use the JSL icon at the top of Discussion Preview to enter your JSL
