dadawasozo
read and save a txt file from a subdirectory of a ZIP file
Can someone help. I tried many and still fail.
I tried to loop through a list of zip folder to try to find specific txt file that is under a subdirectory of the zip folder. when I get the filelist  in the zip folder, I saw the txt file as subdirector/mytxtfile_123.log. Below is my script, but it fails to download the txt file. there is IO problem where it complains "system cannot find the path specified". I wonder if the flipped of "\" to "/" when I get the filelist. Is there a neat way to get the file in subdirectory or a zip ?
path == path where all zip folder located;
path1 == path where txt file going to save;
lst = {the list of the zip folders};
for (k=1, k <=N items(lst), k++,
	Try(
    za = open(path||lst[k], zip);
    dirlist = za << dir;
    for (l=1, l<=N Items(dirlist), l++,
		If (Contains(dirlist[l], "mytxtfile_"),
			text = za << read(dirlist[l]);
			save text file(path1||lst[k]||"_"||dirlist[l],text);
    print (lst[k] || "fail to open");
    Throw();
Re: read and save a txt file from a subdirectory of a ZIP file
The thing to know about zip files: they do not actually have a nested hierarchical directory structure. A zip file's directory is just a simple list of character string names. Those names might contain / or \ characters, and some zip file viewers might try to represent that as a hierarchical nest. So, the zip file member that has a name that contains mytextfile also contains / characters in the name, and when this path is constructed
save text file(path1  ||  lst[k]  ||  "_"  ||  dirlist[l]  , text);
dirlist contains "test/test/mytextfile.txt" and the resulting pathname from the concatenation probably does not exist on your computer.
The word() or words() functions might be useful for separating the parts of the path.
dadawasozo
I added an example of a zip folder here as example. Below is the error message
dirlist = {"test/12.txt", "test/hello.txt", "test/me/", "test/me/testing.txt", "test/test/", "test/test/mytxtfile.txt"};
IO problem: "mytxtfile" Unable to open in ReadWrite mode.
The system cannot find the path specified.
I didn't (yet) check where your script goes wrong, but there is a version which should save the txt file (requires JMP16+ due to For Each() and Filter Each())
file_of_interest = "mytxtfile.txt";
zip_path = "$DOWNLOADS\test.zip";
save_path = "$DOWNLOADS\586819.txt";
za = Open(zip_path, "zip");
members_in_zip = za << dir;
// take only .txt files
file_paths_of_interest = Filter Each({members}, members_in_zip,
	Ends With(members, file_of_interest);
If(N Items(file_paths_of_interest) == 0,
	Throw("Not found");
// Assume that only one of those files exist
file_path_of_interest = file_paths_of_interest[1];
data = za << read(file_path_of_interest, Format("string"));
Save Text File(save_path, data);
//Open(save_path);
