I see the below agreement report that shows these numbers between raters, but I am wanting the numbers that align with the first graph which shows agreement between raters for each part.
I spent a lot of time researching this problem. The plot at the platform's top does not use a graphics script. It uses custom segments to render the points and the lines, but I cannot access them.
I suggest that you contact JMP Technical Support ([email protected]) so they can create a ticket to look into this matter.
If I were to transpose the data and have raters on the y axis and cases on the x axis, would the values in the table below the second chart illustrate what I am looking for?
