hogi
Level XIII
private data table vs. private data table
where can I find an official documentation about the difference between:
dt = Open( "$SAMPLE_DATA/Big Class Families.jmp" );
dt << set private();
and
dt = Open( "$SAMPLE_DATA/Big Class Families.jmp" , private);
Set Visibility of Data Tables
Private yes/no?
Turning Private data tables on and off
8 REPLIES 8
hogi
Level XIII
Re: private data table vs. private data table
e.g.
dts = Get Data Table List();
for each({dt},dts, close(dt) );
dt << set private(1);
dts = Get Data Table List(); // empty current data table(); // Big Class
from https://community.jmp.com/t5/JMP-Wish-List/Set-Visibility-of-Data-Tables/idc-p/769337/highlight/true... / @hardner
My guess would be that << Set Private() is some old implementation or for some very specific use cases but it uses incorrect name for the message as the table isn't private
wait(0);
Print(dt << Get Window View()); // "Visible"
dt << Set Private;
wait(0);
Show(Current Data Table());
dt = Open("$SAMPLE_DATA/Animals.jmp", Private);
wait(0);
dt1 = Open("$SAMPLE_DATA/Big Class.jmp");
Print(dt << Get Window View()); // Scriptable[]
Show(Current Data Table()); // Current Data Table() = DataTable("Big Class");
Current Data Table(dt);
wait(0);
wait(0);
Close All(Data Tables, No save);
Scripting Guide > Data Tables > Basic Data Table Scripting > Hide a Data Table
Scripting Guide > Data Tables > Basic Data Table Scripting > Create a New Data Table
hogi
Level XIII
Is new table("test", private) and new table("test",visibility( "private" )) the same?
@hogi wrote:
Iprivate and visibility( "private" ) the same?
I have no idea what you mean with private
I'm pretty sure all of private, "private" and visibility("private") are mostly the same. Some might be there for backward compatibility purposes (no idea which though with how the JMP documentation is sometimes).
dt1 = New Table("Private1", Private);
dt2 = New Table("Private2", "Private");
dt3 = New Table("Private3", Visibility("private"));
Show(dt1, dt2, dt3);
Close(dt1, no save);
Close(dt2, no save);
Close(dt3, no save);
hogi
Level XIII
So, the only deviation is:
dt4 = New Table("Private4", <<set private(1));
This post seems to be more complex than it should be.  My experience with setting a table to be private is basically to CREATE a table in memory that has no windowing elements, thus saving memory space and additionally, the table does not appear in the JMP Home Window.
As far as I know, a private table cannot be made visible, and standard visible table can not be made private.  The somewhat confusing issue is that a visible table can be made "Invisible" (not displayed).  But it will be listed in the JMP Home Window.
hogi
Level XIII
Agree, this post is much more complex than it should be.
A private data can be made visible via:
dt1 << new data view()
What is puzzling:
a data table can receive the command << set private(1) to "make the data table "private":
surprisingly, this "private" if very different from the "private" in
... and not even as private as advertised by the scripting index:
A nice trick to  "make a data table dt private" - I mean: the other "private":
clone it via
tmp= dt;
dt = tmp << Subset( All rows, Selected columns only( 0 ), "private" );
close(tmp, no save);
from: Turning-Private-data-tables-on-and-off @vince_faller
Colleagues, AI: I hope this info helps ...
