Surface of 3D-Plot
Hi everybody,
I'm new to JMP and need help concerning my 3D Plot. I depicts multiple voltage measurements. I want to show the change in channel 2 voltage over the run number. Therefore I'm searching for a functionality to plot the surface. Does anybody have an idea which functionality is best to use for this usecase? I've tried several, but either they're not doing the stuff I want or the programm crashes.
Re: Surface of 3D-Plot
If you are seeing crashes, especially repeatable crashes please submit the crash report logs and contact JMP Technical support.
If hardware acceleration is enabled, try turning it OFF, If it's off try turning it ON.  It's on the 3D graph's context menu (rt-click)
Key information for technical support:
  • Exact JMP Version
  • Operating System Version
  • system RAM
  • script or key steps to repeatedly cause crash.
  • Your Graphics device info - vendor, onboard graphics or discrete GPU
  • Is your system ARM64 or Intel x86_64.
  • Have you tried updating your graphics drivers?  Especially if running with 'Use Hardware Acceleration'
