Level XII
placeholder for the last returned value
In Mathematica, one can use "%" as a placeholder for the last returned value.
Is there something similar in JMP?
Then one could use the fact that a reference to an object is returned by the function which creates the object.
Could help during debugging:
Run single lines of the original code, add some test code and get a quick reference to a created object via the placeholder.
Names Default to Here(1);
dt << Graph Builder(
	Size( 437, 413 ),
	Graph Spacing( 4 ),
	Elements( Points( X, Y, Legend( 1 ) ), Smoother( X, Y, Legend( 2 ) ) )
// during debugging:
gb = %;(gb << XPath( "//AxisBox" )) << select;
// or even better: gb << get XML(); New Window("xml", %)
Re: placeholder for the last returned value
No, there is no way to retrieve the value. You could move the "gb =" to just before the "dt<<GraphBuilder" to capture it.
Level XII
I posted a wish :
https://community.jmp.com/t5/JMP-Wish-List/JSL-debugging-placeholder-for-last-returned-value/idi-p/5...
and added another example in the code above.
Let's see if other users are also interested ...
sure: If you had this comfort in Mathematica, you kind of miss it in JMP.
Could be that you don't miss it if you didn't have it
pauldeen
Interesting idea, I kudo'd your wish list item.
I usually work around the absence of this by nesting more things into each other...but it can become difficult to read:
gb = dt << Graph Builder(
	Size( 437, 413 ),
	Graph Spacing( 4 ),
CapturedXML = gb << XPath( "//AxisBox" )[1] << get xml; //Like so
