  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
JSL debugging: placeholder for last returned value
☐ cool new feature
☐ could help many users!
☐ removes a „bug“
☑ nice to have
☐ nobody needs it
In Mathematica, one can use "%" as a placeholder for the last returned value.
Could you please implement something similar in JSL?
Could help during debugging:
Run single lines of the original code, add some test code
important: don't mess up the original code lines,
but instead: get access to the return values via the placeholder .
Aditional benefit: work gets focused on "forward direction":
Ah, there is some returned value, how to continue and get most out of it ...
instead of
How do I have to change the previous code to get access to the returned value.
Names Default to Here(1);
dt << Graph Builder(
	Size( 437, 413 ),
	Graph Spacing( 4 ),
	Variables( X( :height ), Y( :weight ), Overlay( :sex ) ),
	Elements( Points( X, Y, Legend( 1 ) ), Smoother( X, Y, Legend( 2 ) ) )
// during debugging:
gb = %;(gb << XPath( "//AxisBox" )) << select;// or even better:
gb << get XML();
New Window("xml", %)
https://community.jmp.com/t5/Discussions/placeholder-for-the-last-returned-value/m-p/568699
3 Comments
kayleewarren
@hogi Thank you for your suggestion! We have captured your request and will take it under consideration.
SamGardner
Level VII
SamGardner
Level VII
Status changed to: Not Planned For Now
@hogi thank you for the idea.  After some review, we have decided to not pursue this.
