KellyT
perform calculations using selected columns
I am struggling to find a good scripting solution for this.  I would like to select a few columns and then perform calculations across them.  The selected columns are flexible, sometimes it could be 2 but sometimes it could be 10+ columns to perform this calculation.
For example
ABCnew column with formula sqrt(sum(A^4, B^4, C^4)
123...
456...
789...
At this moment, I have the script to extract selected column. But once they are in a list with column name, I don't know how to sum up the column using the formula I have above...
cols = dt << get selected columns;
Thank you so much for your help!
Re: perform calculations using selected columns
Here is, using JSL,
dt << New Column( "Calc",
	formula(
		mat = [];
		For( i = 1, i <= N Items( cols ), i++,
			mat = mat || Column( cols[i] )[Row()]
		mat = Sqrt( Sum( mat ^ 4 ) );
dt:calc << delete formula;
how I would create a formula column to handle your issue
I chose the method to use, based upon the very nice capabilities the Matrix operators have in JSL.  The statement
is an illustration of how nice and concise the calculations can be made using matrices.
But to use matrix operators, the data must be in a matrix. So for each row, the matrix Mat is first set to being an empty matrix
mat = [];
and then the For() loop takes each of the columns specified in the << Get Selected Columns and adds the value for that column for the given row, to the matrix "Mat" as a new element in the matrix.  It is "Concatenating" the value of the column for the current row to the matrix.
Here is, using JSL,
	formula(
		mat = [];
KellyT
Thank you Jim! Your script is very helpful as always.  To help me understand JSL better, can you please elaborate what this line of code does?
mat = [];
