- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
parameter interactions
This post originally written in French and has been translated for your convenience. When you reply, it will also be translated back to French .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: parameter interactions
Here are my thoughts:
1. I'm not sure what you mean by other tools? There are a number of methods to build/analyze models. Typically models are analyzed using the fit model platform:
I personally like to visualize interactions, so interaction plots are quite useful.
2. How JMP handles the estimation of interaction effects is dependent on the type of data (e.g., nominal, ordinal, continuous) and how the data was acquired. Interactions between variables are commonly coded as the product of two independent variables in statistical analysis. This practice is based on the concept of interaction effects, which refers to the combined effect of two or more variables on an outcome. When the effect of a factor depends on another factor, this is an interaction. For continuous variables in an experiment, the levels are coded equidistant centered on zero (e.g., -1, 1 for 2-level factors). The coding "normalizes" the coefficients to make analysis easier. If you code your variables, then, indeed the interaction of A*B is the product of the main effects A and B:
A B A*B
-1 -1 1
1 -1 -1
-1 1 -1
1 1 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
How I could create a C=height*weight parameter (in terms of interactions)
Cordially
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Sorry, not enough context to provide specific advice and your data is not from an experiment. R-square is just one of several statistics used to assist in building a model (delta R-square-R-square adjusted, RMSE, residuals, p-values, etc.). I looked at your data table and I'm a bit confused...what is the response variable you are trying to model? Is it weight (this is what your fit model is modeling in the saved script)? If the response is weight, you would not put the interaction of height*weight into the model (height is the predictor and weight is the response variable) Also confused because the R-Square adjusted for that fit model is 0.649...don't know where the .55 comes from? Height and weight are correlated (r=.71) and there are some outliers in your data (both multivariate and residuals).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
I agree with @statman wrt to the usefulness of interaction plots. And if you really want to impress your friends at cocktail parties, use the JMP Prediction Profiler slider bars for one of the terms and watch the slope of the second term change as you slide the one term from left to right and back.
