one sided confidence interval in capability calculations
Hi i need to calculate the lower bound ppk with one sided CI of 95
The default option is two sided how can i calculate onle the lower bound ppk without the upper CI
in minitab this option exist see attached , where is the same option in JMP
Re: one sided confidence interval in capability calculations
Not 100% sure, but I think you might have to calculate two-sided 90% confidence interval and then use only the lower confidence interval One-sided confidence intervals for proportions
Is there an option to remove the upper CI in the setting? the results change based on that and i cant perform it manually because i need to show the final  result in the report
