Jackie_
Create New Column if the list contains
I have a list which contains column names. I want to create a new column if the column name exist in the string list.
Here's my code. It works but creates duplicate column names bc of the loop. Any advice?
Clear Globals();
Clear Log();
dt = Current Data Table();
col_list = dt << Get Column Names( string );
idds = {52,54};
For( i = 1, i <= N items( idds ), i++,
  If( Contains( col_list, Char( idds[i] ) ),
   dt<<Column( "%_IDD", Numeric, "Continuous", Format( "Percent", 12, 2 ));
 Thanks
Re: Create New Column if the list contains
Your code will create a new column for every column found in your idds list.  This code checks to see if the column already exists and if it doesn't it will create it.
Clear Globals();
Clear Log();
idds = {52, 54};
For( i = 1, i <= N Items( idds ), i++,
	If(
		Contains( col_list, Char( idds[i] ) ) & Try( Column( dt, "%_IDD" ) << get name, "" ) ==
		dt << New Column( "%_IDD", Numeric, "Continuous", Format( "Percent", 12, 2 ) )
Clear Globals();
Clear Log();
idds = {52, 54};
	If(
