farida
non parametric KS test of two samples
How to do non-parametric kolmogorov smirnov test with two sapmle using jmp? I have long time series data, so which format do I need to do for the input in jmp? I mean excel, or text file etc?
Re: non parametric KS test of two samples
The Kolmogorov-Smirnov test is available under the Fit Y by X Platform.  The Statistics Index provides an example
     Help==>Statistics Index==>Kolmogorov-Smirnov
JMP allows you to read data in from either Excel or txt files.  The format for the data needs to be in 2 columns.  One that contains the measurement data, and a second column which shows which of the 2 groups you are testing, each data value goes with.  See the example below
sex	age
Male	36
Male	23
Male	29
Male	39
Male	34
Female	42
Female	40
Male	28
sex	age
Male	36
Male	23
Male	29
Male	39
Male	34
Female	42
Female	40
Male	28
farida
Thanks for nice reply. It was really helpful.
