Nagraba
How do I get the import file settings right before concatenating files by a script?
I have several files in a specific format and and with the *.asc extension (example: two files as attached to this post). I have tried to make changes in the script uploaded by Bryan can be found here: https://community.jmp.com/t5/JMP-Scripts/Combine-multiple-txt-or-csv-files/ta-p/24083
It works well if I rename all my files to *.txt before running the script but otherviese it will not. I have tried to make changes into the script below (from Bryan) but still can not get it to work.
Can anyone help me getting the right mport file setting and *.asc filters in the script?
Thanks
Craige_Hales
Re: How do I get the import file settings right before concatenating files by a script?
You can use open("filename.asc","text") to get JMP to assume the file is a text file of data for import. I got this script out of the table after importing via the preview wizard. Since it has other options, it doesn't need "text". On the file-open dialog, set the filter to *.*, pick your file, then set the filter to *.txt and pick the preview wizard. Look in the imported table's source script to find...
Open(
	"C:\Users\...\Desktop\Example01.asc",
	columns(
		New Column( "Column 1", Character, "Nominal" ),
		New Column( "0s", Numeric, "Continuous", Format( "Best", 12 ) ),
		New Column( "90s", Numeric, "Continuous", Format( "Best", 12 ) ),
		New Column( "180s", Numeric, "Continuous", Format( "Best", 12 ) ),
		New Column( "270s", Numeric, "Continuous", Format( "Best", 12 ) ),
		New Column( "360s", Numeric, "Continuous", Format( "Best", 12 ) ),
		New Column( "450s", Numeric, "Continuous", Format( "Best", 12 ) ),
		New Column( "540s", Numeric, "Continuous", Format( "Best", 12 ) ),
		New Column( "630s", Numeric, "Continuous", Format( "Best", 12 ) ),
		New Column( "720s", Numeric, "Continuous", Format( "Best", 12 ) ),
		New Column( "810s", Numeric, "Continuous", Format( "Best", 12 ) ),
		New Column( "900s", Numeric, "Continuous", Format( "Best", 12 ) ),
		New Column( "990s", Numeric, "Continuous", Format( "Best", 12 ) ),
		New Column( "1080s", Numeric, "Continuous", Format( "Best", 12 ) ),
		New Column( "1170s", Numeric, "Continuous", Format( "Best", 12 ) ),
		New Column( "1260s", Character, "Nominal" ),
		New Column( "1350s", Character, "Nominal" ),
		New Column( "1440s", Character, "Nominal" ),
		New Column( "1530s", Character, "Nominal" ),
		New Column( "1620s", Character, "Nominal" ),
		New Column( "1710s", Character, "Nominal" ),
		Omitted Column( . )
	Import Settings(
		End Of Line( CRLF, CR, LF ),
		End Of Field( Tab, CSV( 0 ) ),
		Strip Quotes( 1 ),
		Use Regional Settings( 0 ),
		Scan Whole File( 1 ),
		CompressNumericColumns( 0 ),
		CompressAllowListCheck( 0 ),
		Labels( 1 ),
		Column Names Start( 1 ),
		Data Starts( 2 ),
		Lines To Read( "All" ),
		Year Rule( "20xx" )
Craige
Craige_Hales
Open(
	columns(
		Omitted Column( . )
	Import Settings(
		Strip Quotes( 1 ),
		Labels( 1 ),
		Data Starts( 2 ),
		Year Rule( "20xx" )
Craige
