Created:
Mar 17, 2022 03:43 PM
| Last Modified: Jun 11, 2023 4:22 AM(1783 views)
I just upgraded from JMP 15 to 16 on my Mac. Before, I could change the color theme in a contour plot under the red triangle (I prefer to look at my plots with a spectral theme). I no longer see that option with version 16. Is there somewhere else I can change the default red to blue to a spectral theme for contour plots?
