rrtx_mike
jsl to create table subset of most frequent values in a column
Hello All,
I'm a new user who is still learning the basic fundamentals and usually I can find the answers I need by searching but this one is eluding me.
I'm looking for a script to create a table subset of the top 10 most frequently occurring values of a selected column. My current work around is to create a summary table, sort the summary table by descending value, select the top ten rows, and then go back to the first table and create a subset of the selected rows. I'm certain there is an elegant solution but I just can't find it. Thanks!
Re: jsl to create table subset of most frequent values in a column
Here is a sample script that works using only the top 5 selections, since the sample data table is so small.  But I think you can see how it works.
Names default to here(1);
dt=open("$SAMPLE_DATA/big class.jmp");
dtsumm = dt << Summary(
       Group( :height ),
       Freq( "None" ),
       Weight( "None" )
dtsumm  << Sort( By( :N Rows ), Order( Descending ), Replace Table(1) );
dtsumm << select where(row()>5)
dtsumm << delete rows;
dtfinal = dt << Join(with(dtsumm) ,
       By Matching Columns( :height = :height ),
       Drop multiples( 0, 0 ),
       Include Nonmatches( 0, 0 ),
       Preserve main table order( 1 )
       Group( :height ),
       Freq( "None" ),
       Weight( "None" )
rrtx_mike
Thanks Jim, this worked perfectly.
ms
Super User (Alumni) ms
One alternative would would be use Summarize() instead of a summary table, and then also skip the sorting step by utilizing the Rank() function. Unfortunately, the stat options in Summarize is limited to numeric columns; the below sample script will thus not work for character columns.
dt = Open("$SAMPLE_DATA/big class.jmp");
n = 3; // Nr of most frequent values
Summarize(g = by(:age), c = Count(:age));
dt << subset(rows(dt << select where(Contains(Reverse(g[Rank(c)])[1 :: n], Char(:age)))));
rrtx_mike
Hi MS,
Thanks for your response, I should have mentioned in my original post that the data I was interested in was character and not numeric. But I am bookmarking your reply as I will need to perform the same summary with numeric data in the future.
