snagpal
JSL to change color of specific cause in Pareto Plot
I'm trying to change the color of a specific cause in the Pareto Plot using JSL.  How can I select a cause by name?
For example, I want to implement something like this:
cause ({"PASS"}) << Colors (Green);
This gives me an error and wants me to use Cause where n is the index of the failure pareto.  My issue is that I won't know if my PASS pareto will be #1, #2, etc.
Any suggestions?
Here is my code below:
dt << Pareto Plot(
  Cause( :BinName),
  Colors (Red),
  Dispatch( {}, "Pareto Plot", OutlineBox, {Set Title( "Pareto of " || (dt << Get Name) )} ),
  Dispatch( {"Plots"}, "102", ScaleBox, {Label Row( Show Major Grid( 1 ) )} )
Shin
Re: JSL to change color of specific cause in Pareto Plot
Hi, Shin.
The following example demonstrates how you can determine the index and color a specific cause by name:
dt = Open( "$SAMPLE_DATA/Quality Control/Failure Raw Data.jmp" );
/* Obtain the sorted frequency */
dtSumm = dt << Summary( Group( :failure ), private );
dtSumm << Sort( By( :N Rows ), Order( Descending ), Replace Table );
/* Obtain the row number for the desired cause specified by name */
r = (dtSumm << Get Rows Where( :Failure == "oxide defect" ))[1];
/* Generate the Pareto Plot */
pPlot = dt << Pareto Plot(
      Cause( :Failure ),
      Colors( "Red" ),
          /* Set the color for the desired cause */
      Cause[r] << Colors( "Green" ),
              Dispatch(
                                    "Pareto Plot",
                    OutlineBox,
I hope this helps.
Wendy​
Wendy
snagpal
Hi Wendy,
That was perfect.  Thanks for  the solution.
Shin
