aliegner1
jsl: how to plot using a list of groups?
following up from this post: https://community.jmp.com/t5/Discussions/Script-to-loop-thru-and-group-columns-by-name-dynamically/m...
I'm grouping 10k+ columns into groups by StepID, but now trying to plot them all.
I can't quite figure out how to tell it to plot by the list of all the groups. any advice?
/*plotting a basic Fit YbyX just to get pValues. Formatting and style done on final plot*/
ow1 = Oneway(
	Y( dtAggWide<<get column group( "10.0.0.0.0.0" ) ),
	X( :ChamberId ),
	//By(:),
	//All pairs Tukey HSD test
	All Pairs(
		1,
		Confidence Quantile( 0 ),
		Difference Matrix( 0 ),
		LSD Threshold Matrix( 0 ),
		Connecting Letters Report( 0 ),
		Ordered Differences Report( 1 )
	//invisible, //use this to speed up.
Re: jsl: how to plot using a list of groups?
Here is a rewrite of the code, removing the need for expression building
dt<< set name( "AggWide" );
//get the column groups and put them into one long list
colgroupNames = dt << get column groups names;
colsList = {};
For( i = 1, i <= N Items( colgroupNames ), i++,
	Insert Into( colsList, dt << get column group( colgroupNames[i] ) )
//temporary string for testing
RecipeStepIndex = {"10.0.0.0.0.0", "11.0.0.0.0.0", "12.0.0.0.0.0"};
// Build a character string that represents the commands that need to be run
ow1 = Oneway(
	Y( Eval( colsList ) )
	X( :ChamberID ),
	//By(:),
	All Pairs(
		1,
You can most likely do it with something like this (you need EvalEvalExpr):
dt << Group Columns("group1", {"height", "weight"});
Eval(
	EvalExpr(
		dt << Oneway(
			Y(Expr(dt << Get Column Group("group1"))),
			X(:age)
See Insert one expression into another using Eval Insert, Eval Expr, Parse, and Substitute for more information and examples about Eval(EvalExpr())
aliegner1
I'm sorry, i'm struggling here.
I'm not sure why nesting the evalexpr?
is there not a way to replace the
with a list of column groups?
I previously created this list, how can I swap this RecipeStepIndex into the Y groups
//Build and prefill an Array of names of the RecipeStepId
Summarize( dt, RecipeStepIndex = by( :RecipeStepId) );//get list of unique RecipeStepID's
aliegner1
OK, so I've got this, but I'm not sure how I can keep looping and creating new terms inside the Y( section.
any advice?
ow1 = Oneway(
Y( dtAggWide<<get column group( colgroupNames[1] )
, dtAggWide<<get column group( colgroupNames[2] )
, dtAggWide<<get column group( colgroupNames[3] )
X( :ChamberId ),
//By(:),
All Pairs(
1,
);dtAggWide = current data table(); dtAggWide << set name( "AggWide"); RecipeStepIndex ={"10.0.0.0.0.0", "11.0.0.0.0.0", "12.0.0.0.0.0"} // column groups names. Each group has 100+ columns. //trying to create a series of charts using the groups, looping through the groups ow1 = Oneway( Y( for( i = 1, i<=Nitems( RecipeStepIndex), i++, dtAggWide<<get column group( RecipeStepIndex[i] )) ), X( :ChamberId ), //By(:), //All pairs Tukey HSD test All Pairs( 1, Confidence Quantile( 0 ), Difference Matrix( 0 ), LSD Threshold Matrix( 0 ), Connecting Letters Report( 0 ), Ordered Differences Report( 1 ) ), //invisible, //use this to speed up. );
aliegner1
so I ripped this solution from @txnelson : https://community.jmp.com/t5/Discussions/Script-multiple-columns-grouped-in-distribution-plot/td-p/1...
but wondering if there's a way to just loop through the group names rather than doing this expression building thing.
theExpr_start = "ow1 = Oneway(
	Y( dtAggWide<<get column group( colgroupNames[1] )";
theExpr_end = "	),
	X( :ChamberId ),
	//By(:),
	All Pairs(
		1,
//Loop across the remaining column groups in the colgroupNames list and generate the series of charts
For( i = 2, i <= N Items( colgroupNames ), i++,
	theExpr_start = theExpr_start || ", dtAggWide<<get column group( colgroupNames[" || Char( i ) || "] )"
//combine the strings
theExpr_final = theExpr_start || theExpr_end;
//Execute the code generated and placed into the character string variable
Eval( Parse( theExpr_final ) );
colsList = {};
ow1 = Oneway(
	X( :ChamberID ),
	//By(:),
	All Pairs(
		1,
TDF
TDF
Thank you very much, none of my post reading had discovered the get function helping to draw that information out.
TDF
TDF
Many thanks that solved the problem.  My post reading had not discovered the get function to draw out the information I required.
