Level XIII
jsl code to change the "view" for a graph builder plot with X grouping?
the "group X" option generates 2 plots, one for "F" and one for "M".
The option "First View Level" can be used to specify which "view" to start with , here:  "M" (2nd view).
is there a JSL code to prgrammatically change the "view", something like
gr << Set X View Level (1)
gr = dt << Graph Builder(
	Variables( X( :height ), Y( :weight ), Group X( :sex, N View Levels( 1 ),First View Level( 2 ) ) ),
	Elements( Points( X, Y, Legend( 20 ) ), Smoother( X, Y, Legend( 21 ) ) )
The idea:
- selection of a data point is (in another graph) triggers the plot to show the respective subgroup
- the user still has the possibility to go to another subgroup
- in the giu, "X group" is much small than a local data filter
Re: jsl code to change the "view" for a graph builder plot with X grouping?
I'm not sure if this is only method, but you might have to manipulate Variables.
Here is one example, it first adds new grouping variable and then deletes variable in index 3 which in this case is the "old" grouping.
gb = dt << Graph Builder(
	Variables(X(:height), Y(:weight), Group X(:sex, N View Levels(1), First View Level(2))),
	Elements(Points(X, Y, Legend(20)), Smoother(X, Y, Legend(21)))
gbb = Report(gb)[Graph Builder Box(1)];
wait(2);
//gbb << get variables;
gbb << Add Variable({:sex, Role("Group X"), Position(1), N View Levels(1), First View Level(1)});
gbb << Remove Variable(3);
wait(2);
Level XIII
very creative workaround :)
