HSS
HSS
issue in for loop
hello All, I am not able to figure out why this for loop formula is not working. It simply creating a new column if units are in time and then covert it into Hours. Sample data is also attached. Thanks.
ColNames = dt << get column names( string, Numeric, character, continuous, Nominal );
N Items( ColNames );
For( i = 1, i <= N Items( ColNames ), i++,
If( Ends With( ColNames[i], "(secs)" ),
New Column (Concat(ColNames[i], "_to_", "Hr"), Formula(AS Column(ColNames[i])/3600) ),
Ends With( ColNames[i], "(min)" ),
New Column (Concat(ColNames[i], "_to_", "Hr"), Formula(AS Column(ColNames[i])/60) ),)
Wait( 0 );
Re: issue in for loop
The issue is that the Formula element does not parse the formula presented and then place the resulting code into the formula.  Therefore, what is presented to the formula element, needs to be exactly the JSL the formula needs to be.  Below is a rework of your jsl
dt = Current Data Table();
//N Items( ColNames );
	If(
			New Column( Concat( ColNames[i], "_to_", "Hr" ),
				Formula( Eval( Parse( ":\!"" || ColNames[i] || "\!"n / 3600" ) ) )
				Formula( Eval( Parse( ":\!"" || ColNames[i] || "\!"n / 60" ) ) )
ErraticAttack
You might also consider using JSL Quote(), which allows the code to remain highlighted
Names Default to Here( 1 );
For( i = 1, i <= N Cols( dt ), i++,
	column name = Column( dt, i ) << Get Name;
	If( Ends With( column name, "(secs)" ),
		Eval( Parse( Eval Insert( JSL Quote(
		dt << New Column( "^column name^_to_Hr", Formula( :Name("^column name^" ) / 3600 ) )
		Ends With( column name, "(min)" ),
		dt << New Column( "^column name^_to_Hr", Formula( :Name("^column name^" ) / 60 ) )
Jordan
	If(
HSS
HSS
Thanks you Jim. it is working.
ErraticAttack
Jordan
HSS
HSS
Thanks Erratic, It is working. Both solutions (from Jim and yourself) working fine. But the solution you have provided - I never saw (JSL Code()). Thank you.
