nac
nac
jmp copy paste graph builder into word
Dear all,
ı need a help about JMP copy and paste into office documents. I routinely use JMP graph builder then paste them into word, PowerPoint. But, nowadays, I have an issue for it. When ı paste graphs into word or power points, you can see the below figure, half of the graph is not seen. This situation exists for each graph. Could you please help for this issue?
BR
Re: jmp copy paste graph builder into word
I've seen this happen when a laptop is docked or undocked.  Could that be the case?  If so, does restarting the laptop solve the problem?
Michael_MXAK
We've also seen this, and it seems to happen when the resolution of the display changes while JMP is open (like, as @HadleyMyers mentions, docking and undocking a laptop). Restarting the computer fixes it in the cases I've seen. Sometimes merely restarting JMP works, but not always.
