how to use range check to delete data which out range?
TONYMA
Feb 14, 2017
dear all,
I wang to use range check to delete data which out range
data range: 2016/09/01~2016/10/16
but actually i can not delete data which out range
over 2016/10/16 is still in the data table
how can I  detele data which  out of  range: 2016/09/01~2016/10/16   ?
thanks
you are your god.
1 REPLY
Jun 22, 2012
I am running JMP 13.2.1 and applied the Range Check to your data, and it worked as documented.  Here are the before and after distributions, and an attached copy of the modified data
