BookmarkSubscribeRSS Feed
robust1972
Jan 15, 2014
how to save data table(colored cells) to html?
what I want to achieve is "bitmap", meaning coloring cells by cell value(pass/fail). it is almost done as attached table. but the problem is that JMP does not support zoom in and zoom out function with mouse or keyboard short cuts as MS office and all web browser do. So I would like to publish it as html so that this map could be zoomed.
John_Powell_JMP
May 30, 2014
Solution
Re: how to save data table(colored cells) to html?
I uploaded a JSL script Export to HTML with Pass/Fail Coloring that may help.
Here's a partial image of the HTML output from your jmp table zoomed out in a browser.
I hope this helps.
John_Powell_JMP
May 30, 2014
Solution
I hope this helps.
robust1972
Jan 15, 2014
thanks John for your help!
