Hello
I would like to merge column A and column B into one column.
Actually, I have found a solution to change the numeric type of column A and column B to character type
and after this, use "New Formula Column" >> "Concatenate."
My question is, without changing the numeric type, how can I merge column A and column B into column A&B?
Thank you
Dennis
