zoulanlan
how to get cumulative sum data?
How do I use JMP9 to get cumulative sum data?  That is, I want to accumulate data from column COUNT in a new column called SUM,
COUNT      SUM
0                0
0                0
1                1
1                2
0                2
Thank you for your help!!
louv
Staff (Retired)
Re: how to get cumulative sum data?
Use the Column Formula and enter the above expression using the Statistical>Summation, Row and Column of interest with subscript i
louv
Staff (Retired)
nac
nac
Hi
I have difficulty to understand at the attached formula. Could you please explain what calculation is done by using this formula with an example?
The formula specification for JMP 13.2.1 is:
Col Cumulative Sum( :weight )
