How do I use JMP9 to get cumulative sum data? That is, I want to accumulate data from column COUNT in a new column called SUM,
COUNT SUM
0 0
1 1
1 2
0 2
Thank you for your help!!
Go to Solution
Use the Column Formula and enter the above expression using the Statistical>Summation, Row and Column of interest with subscript i
Hi
I have difficulty to understand at the attached formula. Could you please explain what calculation is done by using this formula with an example?
The formula specification for JMP 13.2.1 is:
Col Cumulative Sum( :weight )
