Mendes-Burak
how to get Plot of several Plots time vs dimensions
I would like to have a script for the dimension control by time, for this I need something like the sketch below. The Date Table is attached. In total there are 49 plots in one plot, 7 time points and 7 dimensions, some of the dimensions are measured in different points (a,b,c,d) then each points should have a certain color.
Thank you everyone
JMP17
Re: how to get Plot of several Plots time vs dimensions
No attached data table was found
Mendes-Burak
You most likely have to stack your data somehow, but I don't understand your data structure enough to give an advice how it should be done (you have column groups which possibly define some time interval but column names give no indication for that and half of those groups are only missing values, then you have Time column and it has 3 rows which have missing values).
