Level XIII
how to generate this graph in Graph Builder?
How to generate a plot in Graph Builder with:
  • color & fit  = Latitude bin
  • marker = Station
like this one:
The plot doesn't look fancy, but most JMP uses will get stuck when they try to adjust the markers.
STATION is used as Color - and "therefore" the user is only allowed to change the color:
Sure, everybody knows a JMP expert - and they will help with a  workaround [what is your favorite one?].
But, Why is this DropZone called "Color" , and why is there no Marker Dropzone when I need one.
Why is it not possible to generate such a simple plot without expert skills?
... why is it not possibility to adjust the Marker, the way the user expects:
For the experts:  Please try to generate a plot with
  • marker = season
  • with Graph Builder [no changes to the data table]
dt = Open( "$SAMPLE_DATA/Functional Data/Weekly Weather Data.jmp" );
dt << New Column( "Latitude_bins",
"Character",
	Formula(
		If(
:LATITUDE < 30, "<30",
			:LATITUDE < 40, "<40",
			:LATITUDE < 50, "<50",
			:LATITUDE >= 50, ">50",
)  << Run Formulas;
Graph Builder(
	Variables( X( :DATE ), Y( :TAVG ), Overlay( :Latitude_bins ), Color( :STATION ) ),
	Elements( Points( X, Y ), Smoother( X, Y ) ),
	Local Data Filter(
		Add Filter(
			columns( :STATION ),
			Where(
				:STATION == {"USW00003949", "USW00012924", "USW00014922",
				"USW00092811", "USW00093067", "USW00094626"}
			Display( :STATION, N Items( 15 ) )
Level XIII
Re: how to generate this graph in Graph Builder?
Maybe a related issue:
Try to adjust the Transparency for the female data points.
There is a function - but without effect!
dt = Open( "$SAMPLE_DATA/Big Class Families.jmp" );
Graph Builder(
	Variables(
		X( :height ),
		Y( :weight ),
		Overlay( :sex, Overlay Encoding( "Style" ) ),
		Color( :height )
	Elements( Points( X, Y ) )
BHarris
I have often wished for both a "Marker" and a "Label" drop zone, and maybe even a "background color" zone.  I haven't submitted those ideas because I'm thinking once I learn more about JMP I'll realize it's a bad idea, but at this point they seem obvious additions.
Level XIII
Label Drop zone, sounds great!
I submitted a related wish some days ago: advanced label control in Graph Builder
the idea: a possibility to deactivate specific columns via the variables control.
I just added another dimension to the wish:
 dynamic label control for rows as an alternative to the current approach via static row states.
That's a bit nerdy, isn't it?
BHarris
I’d love to hear what other options Xan considered for the drop zones, and understand his reasoning for leaving each one out.
Level XIII
I think the philosophy behind Graph Builder is:
- keep it slim!
- provide a basic set of functions to satisfy a large percentage of customer
- DON'T be eager to satisfy all needs
Concerning Marker and Transparency Dropzone the idea might be:
- better NOT frighten the basic users with too many options
- the expert users will  find a workaround
On the other hand, there are many low hanging fruits to help the experts - without frightening the basic users:
- don't disable features - don't remove marker control via Color Dropzone!!
- institutionalize features:new Column Property: Value Markers
- provide PRO features via a secret layer  |  hide them from the basic users:
  e.g.  Graph Builder: support more than 2 'Color' columns -> thanks for the 20x : )
  Same approach:  Graph Builder - Overlay by multiple columns
Concerning Labels, I guess it's like with Hier Box():
GraphBuilder Powers for Fishbone/hierarchical Diagram Platform
 Compared to features which were added later, the functionality feels outdated.
It provides a basic function, but it lacks the comfort of current JMP 19.
Unfortunately, the function is already there. So, there is little demand to get a better version.
