BookmarkSubscribeRSS Feed
Shlomizr
Occasional Contributor
Sep 13, 2018
how to extract string between specific pattern using regexp?
I am new to regex, i need to extract the name of users from their id, for example:
I have the following long string
123450_dan; 154396_kelli; 198756_dev;
Result need to be: dan
What regex do i need to use in order to extract the name dan which have the id 123450?
Thanks in advance.
3 ACCEPTED SOLUTIONS
markbailey
Jun 23, 2011
Solution
Re: how to extract string between specific pattern using regexp?
You did not specifiy much detail about the ID so here are a few examples to get started. I used a JMP script, but this extraction could be used in a column formula, too.
Names Default to Here( 1 );
// test string
string = "123450_dan; 154396_kelli; 198756_dev;";
// assume specific ID
name = Regex( string, "123450_(\w+\b)", "\1" );
Show( name );
// assume first ID with 6 numbers
name = Regex( string, "\d{6}_(\w+\b)", "\1" );
Show( name );
// assume first ID with any number of numbers
name = Regex( string, "\d+_(\w+\b)", "\1" );
Show( name );
gzmorgan0
Jul 25, 2016
Solution
The script that I provided previously using JMP functions would not require any modifications.  The regular expression to capture one or more "names" after the underscore would be (\w+\s*)+ which means accumulate ( ) at  least one word \w+, zero or more spaces \s* and the trailing plus implies repeat the pattern one or more times.
Names Default to Here(1);
string="123450_dan fox; 154396_kelli ann marie; 198756_dev;";
name1 = Regex( string, "123450_((\w+\s*)+\b)", "\1" );
name2 = Regex( string, "154396_((\w+\s*)+\b)", "\1" );
Show( name1, name2 );
/*: name1 = "dan fox"; name2 = "kelli ann marie"; */
markbailey
Jun 23, 2011
Solution
Use this form instead:
name = Regex( string, "123450_([a-zA-Z ]+);", "\1" );
9 REPLIES 9
markbailey
Jun 23, 2011
Solution
// test string
Show( name );
Show( name );
Show( name );
Shlomizr
Sep 13, 2018
Thanks Mark,
Working perfect!!
Shlomizr
Sep 13, 2018
Hi Mark,
Just 1 question, what do i need to add if i have space in the user name:
for example: "123450_dan fox; 154396_kelli; 198756_dev;"
I tried the following Regex:
string="123450_dan fox; 154396_kelli; 198756_dev;"
name = Regex( string, "123450_(\w+ | \s+)", "\1" );
Show( name );
Result: "dan" instead of "dan fox"
Thanks in advance.
markbailey
Jun 23, 2011
Solution
Shlomizr
Sep 13, 2018
Thanks, work perfect.
markbailey
Jun 23, 2011
Assuming that you want fhe name associated with a specific ID in the parttern "id_name;", then this version will work, too.
// test string
// target ID
id = "123450";
name = Regex( string, id || "_(\w+);", "\1" );
Show( name );
gzmorgan0
Jul 25, 2016
Just for fun, and because regular expressions can be tough to read by others (or two weeks later), Here is an alternative, using JMP functions.
// test string
//create a list of id_name
id = Words(string, ";");
//create a list if ids, a list if names, an associative array(keyed list)
idlist={};
namelist={};
lookup = [=>""];  //Associative Array that retuns an empty string, if number is not valid
for(i=1, i<=nitems(id), i++,
   InsertInto(idlist, num(word(1,Trim(id[i]),"_")) );
   InsertInto(namelist, Titlecase(word(2,Trim(id[i]),"_")) ); //don't need TitleCase
   lookup[idlist[i]]=namelist[i]  //ids are the keys and names are the values
show(id, idlist, namelist, lookup, lookup[198756], lookup[128954]); //last one is not valid
gzmorgan0
Jul 25, 2016
Solution
Shlomizr
Sep 13, 2018
Thanks, work perfect!!
