robust1972
how to do floor plan within JMP
What I intend to achieve is draw a rectangle fill with rectangles with difference sizes. I attached the data. Any helps or hints will be very appreciated, Thanks!
Re: how to do floor plan within JMP
Here is a simple script to do what you want
dt = Data Table( "floor plan map data" );
New Window( "floor plan",
	Graph Box(
		X Scale( -20000, 40000 );
		Y Scale( -20000, 40000 );
		For( i = 1, i <= N Rows( dt ), i++,
			Rect(
				:Name( "Center X" )[i] - :Size_X[i] / 2,
				:Name( "Center Y" )[i] + :Size_Y[i] / 2,
				:Name( "Center X" )[i] + :Size_X[i] / 2,
				:Name( "Center Y" )[i] - :Size_Y[i] / 2
8 REPLIES 8
mlo1
There was a talk on this topic at a User meeting: Benutzerdefinierte Karten für nicht-geografische Daten
	Graph Box(
			Rect(
robust1972
Thanks Jim!
I did not run properly on my PC. Did you post part of the script only?
I apparently posted the wrong script.....
I have corrected the script
robust1972
Hi Jim,
Do you think it is possible to label the rectangles with the text in column contains "a, b, c..."
Thanks in advance!
The JMP Graphic primitives are a very complete graphing environment, so of course you can add text.  Look in JMP Scripting Index in the Graphics Functions.  There you will find the Text() function
robust1972
thanks!
This discussion might help, too.
