Shlomi
how to create 2 text lines in one table cell
Hello
I wolud like to write into one table cell long string. Is there any option to write the string in 2 lines and put it into same cell (similar to Alt+enter in excel)?
Thanks,
Re: how to create 2 text lines in one table cell
Here is an example, taken directly from
     Help==>Scripting Index
dt << Set Cell Height( 20 );
12 REPLIES 12
JMP does not have such an option.  The row height can be changed, which will allow long strings to wrap within a cell, however, when you change one rows height, all rows will be changed to the same height.
Shlomi
Thanks a lot
ian_jmp
Level X
Perhaps you could put the escape seequence '\!N" in your text?
dt = New Table( "Double Height",
				Add Rows( 1 ),
				New Column( "Column 1", Character, Nominal)
Column(dt, "Column 1")[1] = "The quick\!Nbrown fox";
Shlomi
This one remoce the second part of the string
Thanks,
ian_jmp
Level X
Increase the cell height by dragging:
Shlomi
I am using JMP11 with windows , and does not success to change the hight of the cell.
Is there a JSL code to change the cell height ?
Thanks,
You will need to upgrade to get the cell height capability
Shlomi
Is there jsl splrict to do it in JMP12 or 13 ?
Thanks,
The Cell Height() setting for JSL was first implemented in JMP 12, therefore, you can use JSL to set it.
