bayesfactor
how to change marker size in Graph Builder when using "size"
Untitled.pngIn using Graph Builder, I have a column that controls the marker "size", however they are all smaller than I'd like. Is there a way to change the size scale so that they all get larger by the same factor? Interactive mode is what I'm using, though scripting is fine too.
pmroz
Re: how to change marker size in Graph Builder when using "size"
You can right click on the Size column (Col A) in the legend and select Marker Size.
pmroz
bayesfactor
This works, in my case I had to set the marker size to a custom size way larger than XXXL.
TadGhostal
@pmroz Is it possible within the scripting language to set a minimum and maximum marker size? Like, put arguments inside of
Size( :myCol, [minSize, maxSize])
within the script? I can only find size with respect to font size everywhere inside the help files. :(
Nick_PV_tech
Is there a way to make a legend (or visual scale) that shows the numeric values corresponding to each marker size? For example, in my graph below, the size is determined by the 'MW shipped' column, but the legend gives no indication of the numeric value corresponding to the marker sizes.
-Nick
dcusack
I tried this, but clicking on "size" in the legend and making the marker size bigger only works for the markers that are already visible. One category is just tiny little points, and changing the marker size does nothing for those. Why is this? How can I make that tiny size class bigger and visible?
