See the image below. These are all of the options you can choose to save or add to your data table for a given report in Fit Model.
![Capture.JPG Capture.JPG](https://community.jmp.com/t5/image/serverpage/image-id/8155i9ADC6FB4F89F34F7/image-size/medium?v=v2&px=400)
To get this menu hold your Alt key down and click the red hot spot by your Response in the upper left corner of the Fit Model report.
You can also set up your preferences to output any of the columns for every analysis that you do.
HTH
