guy1
how do i get access into jmp virtual lab
when I try to use the box of JMP virtual lab in the virtual learning environment I got only two option:
Create User
2. Download Course Materials
and when I press on the first option I right away  get the following error: "Password not set successfully"
what can I do to fix it?
thanks you in advance
P_Bartell
Level VIII
Re: how do i get access into jmp virtual lab
Sounds like you may not have a SAS Profile established? If not, go to www.sas.com/profile and select the Create Profile button to establish a Profile.
Thank you for bringing this to our attention. I am having the same issue. Our elearning team ([email protected]) is investigating - they will let you know when the issue is resolved.
Warm regards,
Mia
This issue has been fixed. Thanks again for bringing this to our attention!
Mia
