niallmarsay
how do i apply red triangle settings to all by-group analyses
I'm relatively new to JMP and feel like i must have missed something.
I am performing a simple distribution analysis on my continuous data but I am running the analysis grouped by nominal data.
is there a way for me to apply settings found in the red triangle to all of my grouped data such as a local data filter or synk to data table changes?
or do I have to either do it manually for each one?
Re: how do i apply red triangle settings to all by-group analyses
As @jthi suggest, broadcast will work well for most red-triangle commands.  In the case of the Local Data Filter, you will get a separate filter for each level.  When you update to JMP 18, look for the changes in the Group Platform.  This adds a "group" red-triangle menu that automatically broadcasts most commands.  For features like the Data Filter and Column Switcher, you will get a single object that operates across the group.  In JMP 17.x you can get similar filter behavior through scripting:
New Window("shared filter",
	Data Filter Context Box(
		HListBox(
			dt << Data Filter(Local, Columns(:age)),
			VListBox(
				dt << Bivariate(X(:height),Y(:weight),By(:sex))
Try holding ctrl when you click the red triangle to broadcast commands https://community.jmp.com/t5/JMP-Tips/Broadcast-Commands-Windows/ta-p/686178
		HListBox(
			VListBox(
