JMP Library
Broadcast Commands (Windows)
Holding down the Control key before selecting a command in a report's menu executes that command everywhere it is valid in the report.
For example, to fit a regression line to many scatterplots in a single report, hold down the Control key then select Fit Line. All the scatterplots then have a fitted line.
Control Key with MenuControl Key with Menu
Fit LineFit Line
