west
graph builder define x groups
i am using graph builder to display continuous data on x and y.  if i drag to the top (X group) i get my data in bins (levels as jmp calls them) which is what i want and i can choose how many levels to display but i need to define each level (bin)
right now graph builder chooses the bin and i cannot find how to define manually
jason
pmroz
Re: graph builder define x groups
There's an addin that will let you define the bins:
Interactive Binning
west
downloaded and restarted JMP and cannot find where it is located for binning from graph builder.  can you send a screen shot of one made from x vs y box plots from graph builder please
Jeff_Perkinson
Graph Builder doesn't have a facility for you to specify custom bins for the Group X role.
Instead, you can use the Interactive Binning add-in to create your custom bins in a new column. Then you use that column in the Group X role.
After installing the add-in you'll find the Interactive Binning command in the Add-ins menu.
-Jeff
-Jeff
