doraemengs
getting column name with specific cut-off values
I try to count and get specific column names from these data examples (my real data contained 180 columns and 20000 rows)
I want to select the column that cut-off > 1000
No.A*1:01A*2:01B*9:02C*10:01DR*56:01DP*07_GGet name
110.6709520.2315000.190.5640.89B*9:02, C*10:01
2000009.56
39040.3345.3345.9999.934510.5A*1:01
434.4456645700A*2:01
59190.2135673456678990880A*1:01,A*2:01,B*9:02,C*10:01,DR*56:01
6000000
I try the previous script like this
// Create a sample data table
dt = New Table( "Example",
	Add Rows( 2 ),
	New Column( "A*1:01", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [0, 50000] ) ),
	New Column( "A*2:01", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [0, 50000] ) ),
	New Column( "B*9:02", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [0, 50000] ) ),
	New Column( "C*10:01", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [0, 50000] ) ),
	New Column( "DR*56:01", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [0, 50000] ) ),
//get wanted columns. Assumes that IMC columns start from column 1 and all IMC columns are one after another
colNames = dt << Get Column Names("String");
For(i = N Items(colNames), i > 3000 , i--,
//new column with IMC with value 1
dt << New Column( "Ag", Character,
	<< Set Each Value(
		rowValues = dt[Row(), 0][1::N Items(colNames)]; //get values of row as matrix
		colIndex = Contains(rowValues, 1); //get index of
		If(colIndex > 0, //handle
			colNames[colIndex], //get column name with the index
			""; //when no 1 found use ""
Could you please to correct my scripts, Thank you!
In addition, can I use matrix because of I need to generate the "new column" of 180 column.
Best,
25 REPLIES 25
Re: getting column name with specific cut-off values
Here is some sort of a script, I'm still left with guess work for the correct rules so no idea if it does what it is supposed to do
dt = Open("$DOWNLOADS/Examples_get column name_edit.jmp");
// fix data
For Each({colname}, dt << Get Column Names("Character", "String"),
	If(colname == "Alphabet",
		break();
	Column(dt, colname) << Set Data Type("Numeric") << Set Modeling Type("Continuous");
dt << Delete Columns("get name and value");
dt << New Column("R", Numeric, Ordinal, Formula(Row()));
dt_stacked = dt << Stack(
	columns(
		:"DOA1*01:01,DOB1*01:01_DO1"n, :"DOA1*02:01,DOB1*01:01_DO1"n,
		:"DOA1*03:01,DOB1*01:01_DO1"n, :"DOA1*02:01,DOB1*02:01_DO2"n,
		:"DOA1*01:05,DOB1*02:01_DO2"n, :"DOA1*04:03,DOB1*03:01_DO3"n,
		:"DOA1*06:01,DOB1*04:01_DO4"n, :"DOA1*05:01,DOB1*03:01_DO7"n
	Source Label Column("Label"),
	Stacked Data Column("Data"),
	Output Table("stacked")
rows_to_delete = dt_stacked << Get Rows Where(:Data <= 1000);
dt_stacked << Delete Rows(rows_to_delete);
dt_stacked << New Column("Match", Numeric, Nominal);
For Each Row(dt_stacked,
	alphs = Words(:Alphabet, ",");
	temp_label = Regex(:Label, "(\d\*)", "", GLOBALREPLACE);
	retval = 0;
	For Each({alph}, alphs,
		If(Contains(temp_label, alph),
			retval = 1;
			break();
	:Match = retval;
rows_to_delete = dt_stacked << Get Rows Where(:Match == 0);
dt_stacked << New Column("NewStr", Character, Nominal, Formula(
	:Label || " (" || Char(:Data) || ")"
Summarize(dt_stacked, rs = By(:R));
fixed_rs = Transform Each({r}, rs, Num(r));
vals = Associative Array();
For Each({r}, fixed_rs,
	t = dt_stacked << Get Rows Where(:R == r);
	vals[r] = Concat Items(dt_stacked[t, "NewStr"], ",");
Close(dt_ stacked);
new_col = dt << New Column("Res", Character, Nominal, Formula(
	If(Contains(vals, :R),
		vals[:R]
dt << run formulas;
new_col << Delete Formula;
doraemengs
Thank you, Jarmo. It's work!
doraemengs
It is not matched by biology.
Here is an alternative method that may help with a large number of columns
dt = Open("$DOWNLOADS/Examples_get column name_by cutoff.jmp");
colnames = Remove( dt << Get Column Names( "String" ), 1 ); // drop No column
// Fix data and modeling types
For Each({colname}, colnames,
	Column(dt, colname) << Data Type("Numeric") << Modeling Type("Continuous");
dtStack = dt << Stack(
	columns( colnames ),
	Source Label Column( "ColName" ),
	Stacked Data Column( "Value" ),
	Output Table( "The Stack" )
dtStack << select where( :value <= 1000 );
dtStack << delete rows;
dtStack << delete columns( Value );
dtSplit = dtStack << Split(
	Split By( :ColName ),
	Split( :ColName ),
	Group( :No ),
	Output Table( "Split of The Stack by ColName" ),
	Sort by Column Property
close( dtStack, nosave );
colnames = Remove( dtSplit << Get Column Names( "String" ), 1 );
dtSplit << Combine Columns(
	delimiter( "," ),
	Column Name( "Get Name" )
dtSplit << delete columns( colnames );
dt << Update( With( dtSplit ), Match Columns( :No = :No ) );
Close( dtSplit, nosave );
doraemengs
Thank you, Jim, but it does not work. please see the attached file.
If the script was written to run with a column called "No" followed by numerical columns.  Your supplied data table has 2 character columns in addition to the numeric.  If you remove the columns "Alphabet of interest" and "get name and value" and then run the script, it works fine.
You should be able to easily change the script to compensate for the additional columns.  Either deleting them in the script before beginning the getting the colnames retrieved, or else deleting them from the colnames list before processing the For Each should work.
