ACraig
Can you create a Stacked Data Table with only the selected rows
I have tried it a couple of different ways but none of them seem to work. I am trying to find a way using JSL to create a stacked data table but only with the rows I have selected. I am using the JSL inside of a Workflow.
Data Table( "My Table" ) << Clear Select <<
Select Where( :Name("5 Million") == "Over 5 Million" ) <<
Stack(
	columns(
		:"Baseline Percent Change"n,
		:"District Percent Change"n,
		:"Engineers Percent Change"n
	Source Label Column( "Estimate" ),
	Stacked Data Column( "Percent Change" ),
	Drop All Other Columns( 1 ),
	Output Table(
		"Stack of Fiscal Year 2024 Percent Changes - Over 5 Million)"
	selected rows only(1)
Any help is greatly appreciated.
Byron_JMP
Re: Can you create a Stacked Data Table with only the selected rows
Might have to select, then subset, then stack with the subset.
If you're working with a really large table, use the private or invisible arguments to keep the memory overhead down, but remember to close private tables.
Byron_JMP
