doraemengs
getting column name with specific cut-off values
I try to count and get specific column names from these data examples (my real data contained 180 columns and 20000 rows)
I want to select the column that cut-off > 1000
No.A*1:01A*2:01B*9:02C*10:01DR*56:01DP*07_GGet name
110.6709520.2315000.190.5640.89B*9:02, C*10:01
2000009.56
39040.3345.3345.9999.934510.5A*1:01
434.4456645700A*2:01
59190.2135673456678990880A*1:01,A*2:01,B*9:02,C*10:01,DR*56:01
6000000
I try the previous script like this
// Create a sample data table
dt = New Table( "Example",
	Add Rows( 2 ),
	New Column( "A*1:01", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [0, 50000] ) ),
	New Column( "A*2:01", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [0, 50000] ) ),
	New Column( "B*9:02", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [0, 50000] ) ),
	New Column( "C*10:01", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [0, 50000] ) ),
	New Column( "DR*56:01", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [0, 50000] ) ),
//get wanted columns. Assumes that IMC columns start from column 1 and all IMC columns are one after another
colNames = dt << Get Column Names("String");
For(i = N Items(colNames), i > 3000 , i--,
//new column with IMC with value 1
dt << New Column( "Ag", Character,
	<< Set Each Value(
		rowValues = dt[Row(), 0][1::N Items(colNames)]; //get values of row as matrix
		colIndex = Contains(rowValues, 1); //get index of
		If(colIndex > 0, //handle
			colNames[colIndex], //get column name with the index
			""; //when no 1 found use ""
Could you please to correct my scripts, Thank you!
In addition, can I use matrix because of I need to generate the "new column" of 180 column.
Best,
3 ACCEPTED SOLUTIONS
Re: getting column name with specific cut-off values
You will have to open your table, fix the columns and then run the part where new column is created
dt = Open("$DOWNLOADS/Examples_get column name_by cutoff.jmp", invisible);
colnames = Remove(dt << Get Column Names("String"), 1); // drop No column
// Fix data and modeling types
For Each({colname}, colnames,
	Column(dt, colname) << Data Type("Numeric") << Modeling Type("Continuous");
newcol = dt << New Column("getname", Character, Nominal, Formula(
	valid_idx = Loc(dt[Row(), colnames] > 1000);
	If(N Items(valid_idx) > 0,
		Concat Items(colnames[valid_idx], ", ")
dt << run formulas;
newcol << delete formula;
I strongly suggest you check out Scripting Guide from JMP Help
Most likely doing something like Jim suggested is faster and easier, but you can do something like this with the method I did demonstrate
Summarize(dt, alphs = By(:"Alphabet of interest"n));
aa = Associative Array(alphs, Repeat({{}}, N Items(alphs)));
collist = dt << Get Column Names("String");
For Each({colname}, collist,
	alph = Word(1, colname, "*");
	If(Contains(aa, alph),
		Insert Into(aa[alph], colname);
		Column(dt, colname) << Set Data Type("Numeric") << Modeling Type("Continuous");
str_template = "^col^ (^val^)";
	cols = aa[:"Alphabet of interest"n];
	vals = dt[Row(), aa[:"Alphabet of interest"n]];
	valid_idx = Loc(vals > 1000);
		res = {};
		For Each({{col, val}}, Across(cols[valid_idx], vals[valid_idx]),
			Insert Into(res, Eval Insert(str_template));
		Concat Items(res, ", ");
dt << run formulas;
dt << show window(1);
Here is some sort of a script, I'm still left with guess work for the correct rules so no idea if it does what it is supposed to do
dt = Open("$DOWNLOADS/Examples_get column name_edit.jmp");
// fix data
For Each({colname}, dt << Get Column Names("Character", "String"),
	If(colname == "Alphabet",
		break();
	Column(dt, colname) << Set Data Type("Numeric") << Set Modeling Type("Continuous");
dt << Delete Columns("get name and value");
dt << New Column("R", Numeric, Ordinal, Formula(Row()));
dt_stacked = dt << Stack(
	columns(
		:"DOA1*01:01,DOB1*01:01_DO1"n, :"DOA1*02:01,DOB1*01:01_DO1"n,
		:"DOA1*03:01,DOB1*01:01_DO1"n, :"DOA1*02:01,DOB1*02:01_DO2"n,
		:"DOA1*01:05,DOB1*02:01_DO2"n, :"DOA1*04:03,DOB1*03:01_DO3"n,
		:"DOA1*06:01,DOB1*04:01_DO4"n, :"DOA1*05:01,DOB1*03:01_DO7"n
	Source Label Column("Label"),
	Stacked Data Column("Data"),
	Output Table("stacked")
rows_to_delete = dt_stacked << Get Rows Where(:Data <= 1000);
dt_stacked << Delete Rows(rows_to_delete);
dt_stacked << New Column("Match", Numeric, Nominal);
For Each Row(dt_stacked,
	alphs = Words(:Alphabet, ",");
	temp_label = Regex(:Label, "(\d\*)", "", GLOBALREPLACE);
	retval = 0;
	For Each({alph}, alphs,
		If(Contains(temp_label, alph),
			retval = 1;
			break();
	:Match = retval;
rows_to_delete = dt_stacked << Get Rows Where(:Match == 0);
dt_stacked << New Column("NewStr", Character, Nominal, Formula(
	:Label || " (" || Char(:Data) || ")"
Summarize(dt_stacked, rs = By(:R));
fixed_rs = Transform Each({r}, rs, Num(r));
vals = Associative Array();
For Each({r}, fixed_rs,
	t = dt_stacked << Get Rows Where(:R == r);
	vals[r] = Concat Items(dt_stacked[t, "NewStr"], ",");
Close(dt_ stacked);
new_col = dt << New Column("Res", Character, Nominal, Formula(
	If(Contains(vals, :R),
		vals[:R]
dt << run formulas;
new_col << Delete Formula;
25 REPLIES 25
Here is how I would handle this
names default to here(1);
	Add Rows( 6 ),
		Numeric,
		"Continuous",
		Set Values(
			[10.67, 0, 9040.2999999999993, 34.399999999999999, 9190.2000000000007, 0
		Numeric,
		"Continuous",
		Set Values( [0, 0, 345.30000000000001, 4566, 13567, 0] )
		Numeric,
		"Continuous",
		Set Values( [9520.2299999999996, 0, 345.89999999999998, 45, 3456, 0] )
		Numeric,
		"Continuous",
		Set Values( [15000.1, 0, 999.89999999999998, 7, 6789, 0] )
		Numeric,
		"Continuous",
		Set Values( [90.560000000000002, 0, 345, 0, 9088, 0] )
	New Column( "DP*07_G",
		Numeric,
		"Continuous",
		Set Values( [40.890000000000001, 9.5600000000000005, 10.5, 0, 0, 0] )
dt << New Column( "Get Name",character);
colNames = dt << get column names( continuous,string );
For Each Row(
	theList = {};
	For Each( {col, i}, colNames,
		If( As Column( col ) > 3000,
			Insert Into( theList, col )
	:Get Name = Concat Items( theList, "," );
doraemengs
Hi Jim,
Thank you for your help. However, I have 180 columns and 20000 rows in difference words and I cannot put all of them as following scripts. Could you please provide me with more suggestions?
Thank you
This might be fast enough
dt = New Table("Example",
	Add Rows(20000),
	invisible
colcount = 200;
For(i = 1, i <= colcount, i++,
	newcol = dt << New Column(Char(i), Numeric, Continuous, Formula(
		Random Normal() * 1000
	dt << run formulas;
start = Tick Seconds();
colnames = dt << Get Column Names("String");
dt << run formulas;
wait(0);
end = Tick Seconds();
show(end - start);
doraemengs
Hi Jarmo,
Thank you so much. But the result is "end - start = 0.0333333333255723;" That's not the new table. could you please provide more solutions? please show me the following data table on JMP.
Thank you
My script creates new column "getname" with the values
With your data, after you fix your columns to numeric (and drop No column)
doraemengs
Hi Jarmo,
Thank you for your help but to be honest as in the following attachment, I cannot run the script as you did. when I checked the script (command + 1) shown below. Thank you for your help.
	Add Rows(20000),
	invisible
colcount = 200;
	dt << run formulas;
dt << run formulas;
wait(0);
show(end - start);
end - start = 0.683333333348855;
dt << run formulas;
doraemengs
Hi Jarmo, Do you have any idea for extracting the values of this that are more than the cutoff (if I have 50 columns) with each column name (getname column on an examples)
How do you wish to extract them? Doesn't my solution create new column which has the column names as strings separated by , and space?
Do you wish to check values by column instead of by row? Or something else?
Edit:
If you just want different column list, I would have to know how to filter it. If you just want all columns, remove the Remove() function
For(i = 1, i < 100, i++,
	newcol = dt << New Column(Hex(i), Numeric, Nominal, Values(J(1, N Rows(dt), Random Normal()*1000)));
dt << run formulas;
