My guess is that it is caused by using translated column name and same name in other column + relying on JMP's loose name rules (file Name instead of File Name for column referencing)
New Table("where_is_the_bug",
Add Rows(2),
Compress File When Saved(1),
New Script(
"THE BUG", JSL Quote(Caption(
"column \!"File Name\!"
name: "|| (current data table():file Name << Get Name)||"
values: " || Char((current data table():file Name << Get values));
As String(1)
New Column("File Name",
Character,
"Nominal",
Compact(),
Set Values({"A", "B"}),
Set Display Width(71)
New Column(["de" => "Dateiname", "en" => "File Name"],
Character,
"Nominal",
Compact(),
Set Selected,
Set Values({"C", "C"}),
Set Display Width(83)
Most definitely a bug considering JMP's rules for names but there are easy workarounds.
Created:
Nov 20, 2024 03:49 PM
| Last Modified: Nov 20, 2024 11:29 PM(3448 views)
| Posted in reply to message from jthi 11-20-2024
More than a guess : )
It's interesting ...
that JMP keeps the column name "File Name" internally for the second column - despite the conflict with the other column just save the table script and you will see something like in @jthi 's post
that JMP uses this internal name to find the column - although the "File Name 2" in the table view besides "file Name", you can also access the column via "File Name 2"
that JMP first scans the localized column names - and THEN the original column names (otherwise it would find the first column). The sequence seems to be: 1) column name a: just exact matches 2) localized column names - even approximate matches 3) column name b: approximate matches
where the additional column came from. I tried Concatenate and Update - with English and German settings ... with JMP 18.1 and JMP19EA4.
Created:
Nov 20, 2024 04:06 PM
| Last Modified: Nov 20, 2024 9:35 PM(3436 views)
| Posted in reply to message from hogi 11-20-2024
As a consequence - a JSL code is very "fragile" if a column name is written slight different to the actual column name:
Somebody can add a new column with alternative values. If one of the localized names is similar to the original column name/ the reference in the script JMP will prioritize the new column. This can lead to surprising plots - maybe less obvious ones than this one: <- Graph Builder will use this one
column name: weight
JSL script: Weight
alternative column (at the end of the table): wEiGhT <- Graph Builder will use this one
Using the data table that @hogi supplied, it get the blank values that were originally shown. I then noticed that there is a column called File Name 2 that has blank values for the 2 rows. I then deleted the column File Name 2 and reran the script, and the script displayed
If you change the name of the column File Name 2 the script will also run correctly
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '816058' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '816058') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '816058') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
