PTR50
formulas not working
I am using Windows and JMP 18
Im Having some problems with version 18
My most recent one is that calculation of formulas does not work.  So for example
I have two columns X and Y - both continuous numeric variables  If  make a variable  Z (also numeric continuous) and use a formula in it: X * Y
I get nothing  (just dots)
any ideas??
Re: formulas not working
just use the formula
:X * :Y
or if "It" is the reference to the data table you could specify
It = current data table();
It:X * It:Y
The JMP Log might have an error statement
Level XIII
the easiest way to generate a new column: new formula column right click menu:
and then you can go to the Log and check the code ...
