JMP will suspend normal business operations for our Rest and Recharge Day on Friday, October 2, 2026.
Hey can someone see if you can tell what's wrong with this formula? I want to stay that if any of these column names contains a value that is "EFV" then return the value of 1 for each row into the new column.
