sos012523
formula not automatically evaluated until clicking apply button
Hello. I made a script adding a column with a conditional formula , the output resulted to a null column only until you click apply in the column formula, I want to automatically output it , I asked colleague to try my data and script , it worked with them. what could be the problem with my jmp16.
new column("Remarks01",character,nominal,formula(If( :Remarsk00 == "Y",
    "1_a",
    "2_b"
Thierry_S
Re: formula not automatically evaluated until clicking apply button
The automatic formula evaluation might be suppressed in your data table preferences (top left red triangle menu)
Let us know if this does the trick.
Best,
TS
Thierry R. Sornasse
Thierry_S
Best,
TS
Thierry R. Sornasse
sos012523
Hi @Thierry_S
thanks for the feedback! seems like it was the problem.
but can you tell when does suppressing usually happens and how to get rid of it?
