BookmarkSubscribeSubscribe to RSS Feed
saitcopuroglu
Community Trekker
Sep 29, 2014
formula for "text to columns"
I have a column with comma seperated values and by using column utilities text to column I get the column for each comma seperated value, however the dataset is growing hourl and by joining/concatenating the new data with the existing one I have to redo all the process again and again. Isn't there a formula for this (or better script)?
Many thanks in advance
KarenC
Feb 10, 2013
Solution
Re: formula for "text to columns"
Look at the "word" formula, for your first column you would use:
Word (1, text, ",")
KarenC
Feb 10, 2013
Solution
Word (1, text, ",")
saitcopuroglu
Community Trekker
Sep 29, 2014
Thank you. Do you have any idea for the second table which has the command of "indicator columns"?
KarenC
Feb 10, 2013
I do not understand what you are trying to do with the second table.  However, for indicator columns I would review the JMP documentation on the categorical (i.e., consumer research) platform as it has ways to work with categorical/indicator data and maybe there is something in there to help you.
saitcopuroglu
Community Trekker
Sep 29, 2014
For second table I also use "text to columns" and this time I tick "make indicator colums" but the result is not formulated by each row, have no idea about scripting it. I already checked the categorical section but hence this transformation is used for financial calculations the categorical can not compute not categorical values like "net revene"... Many thanks
