Here is a simple example.
I developed it interactively by using the Customize Graph designer dialog box available by right clicking on the graph and selecting "Customize".
Once I developed the code, using the Text Template, I then had JMP generate the complete JSL, see below.
Bivariate(
Y( :height ),
X( :weight ),
Fit Line( {Line Color( {212, 73, 88} )} ),
Dispatch(
"Bivar Plot",
FrameBox,
{Add Graphics Script(
4,
Description( "" ),
Text(
Center Justified,
{75, 67},
"R2 = " || Char( Round( (Current Report()[Number Col Box( 1 )] << get)[1], 5 ) )
