BookmarkSubscribeRSS Feed
vince_faller
Mar 17, 2015
find correct axisbox regardless of user preferences
So I'm running into an issue where different user preferences are causing different axis boxes.  I'm tried using xpath but even in that the values are changing for the xpath.
Names default to here(1);
dt = open("$SAMPLE_DATA\Big Class.jmp");
dist = platform(dt, Distribution(
	Stack( 1 ),
	Continuous Distribution(
		Column( :height ),
		Horizontal Layout( 1 ),
		Vertical( 0 ),
		Count Axis( 1 ),
		normal quantile plot(1)
dist1 = platform(dt,
	Distribution(
		Stack( 1 ),
			Column( :height ),
			Vertical( 0 ),
new window("Test",
	dist,
	dist1
axis = dist[axisbox(2)]; // this is right
axis << Add Ref Line(55);
axis = dist1[axisbox(2)]; // this adds it to the y axis, I need 4
Jeff_Perkinson
Community Manager
Jun 23, 2011
Re: find correct axisbox regardless of user preferences
Ignore Platform Preferences(1) will run the platform with the default output. You can use that to ensure that you get exactly the report structure you're expecting.
dt << Distribution(
   Ignore Platform Preferences( 1 ),
   Y( :height, :weight ),
    Histograms Only
-Jeff
vince_faller
Mar 17, 2015
Not really an option.  Customers won't like it if I change what they see.
Wendy_Murphrey
Jun 23, 2011
Hey, Vince.
Have you tried using XPath with the AxisBox and the DisplayBox immediately above it?  For example, the following adds the reference line at 55 on the X axis if I use dist or dist1:
axis = dist1 << XPath( "//BorderBox/AxisBox" );
axis << Add Ref Line( 55 );
Wendy
vince_faller
Mar 17, 2015
I assume this is specific to this specific axisbox because it doesn't have a listbox around it? That's what it looks like at least.
ian_jmp
Jun 23, 2011
Not that this is an answer to your question, but for reference lines maybe you can use the column property?
:height << Set Property( "Axis", {Add Ref Line( 55, "Solid", "Black", "", 1 )} );
	Stack( 1 ),
		Column( :height ),
		Vertical( 0 ),
		Count Axis( 1 ),
	Distribution(
		Stack( 1 ),
			Column( :height ),
			Vertical( 0 ),
new window("Test", dist, dist1);
:height << deleteProperty("Axis");
