dadawasozo
expression column with list compare to given list to replace with desired value
is there a method through add new formula to column for issue below?
I have a column that is list value and I want to compare to given list, if element from list in column match to given list then replace that single element with "1". Below are example. The given list is {"aa", "app", "b", "pp", "zzzz"}
Re: expression column with list compare to given list to replace with desired value
Below is one idea you could use
dt = New Table("Untitled",
	Add Rows(1),
	Compress File When Saved(1),
	New Column("Column 1", Expression, "None", Set Values({{"aa", "bb", "dd"}, {"bb", "2", "cc"}}))
mylist = {"aa", "bb", "cc"};
dt << New Column("res", Expression, "None");
For Each Row(dt,
	rowresult = Transform Each({myitem, idx}, mylist,
		If(:Column 1[Row()][idx] == myitem,
			"1"
			myitem
	:res = rowresult;
dadawasozo
still having issue. The suggestion will only match first element in mylist to first element in :Column 1. Then second to second and third to third. Also if :column 1 has more than 3 elements, the rest will be removed. Below is the result from suggestion
how to enable below.
There was one mistake in my example and I understood incorrectly what you were looking for. This is most likely closer to what you are looking for
	Add Rows(1),
		Expression,
		"None",
For Each Row(
	dt,
	rowresult = Transform Each({item}, :Column 1[Row()],
		If(Contains(mylist, item),
			"1"
			item
	:res = rowresult;
