RA899
Using journal to produce graph builder plots
I'm using journal to produce graph builder histogram distributions. The issue that I'm having is that sometimes the last one or two plots, get compressed and some settings are lost, such as increment which makes the plot unclear.  I tried manipulating the size of the graph builder and all plots changes accordingly besides the last two or sometimes last plot. Any recommendations regarding this issue? Thanks.
Re: Using journal to produce graph builder plots
Could you provide example script to replicate the issue? There might be few different options to avoid the issue depending how you have plotted your data. Have you contacted JMP support about this, it could also be a bug?
