Françoise
error message not understood
Why Have I this message, I don't understand what it means...
Thierry_S
Re: error message not understood
Hi Francoise,
Could you provide the context for this error message: which platform were you using, did you have any row excluded in your table, did you perform your analysis using the "BY" with a column that may have missing information?
Best regards,
TS
Thierry R. Sornasse
Françoise
I use 15.2.1.
I have build a dashboard by scripting.
this message appears when I use the local data filter.
I have no lines excluded.
Thierry_S
Hi Francoise,
It is rather difficult to provide an informed feedback without knowing what your dashboard does but the error message suggest that somewhere in your script, there a process that expects Data and/or Weight which is not populated correctly.
Sorry for not being able to provide a better answer.
Best,
TS
Thierry R. Sornasse
Françoise
OK, thanks !
all the best !
Françoise
I 've tried to do the same with JMP Pro 16 EA8: I 've no error message !
perhaps, someone from R&D JMP can explain it?
best regards
Jeff_Perkinson
We're going to need some more information about what platform is in the dashboard and what the local data filter looks like.
If you're unable to share more information here perhaps you can share more with tech support ([email protected]).
-Jeff
