Josee
If select where does not find value then do x else continue with rest of script
Hello and Happy Friday,
I am trying to find a way around this one. I have a part in my script where it uses the following below. The issue I have is when it does not find the value ABC in Column1. Basically, I want it to where it runs the code below but if it does not find ABC, then I want it to save a blank table (csv) and stop running the rest of the code. If it does find ABC , then I want it to continue with the rest of the code. Any help will be appreciated.
Line 1: dt << select where( :Column1 =="ABC" ););
Line 2: dt2=dt << Subset( Output Table( "ABC" ), Selected Rows( 1 ) ););
Re: If select where does not find value then do x else continue with rest of script
Here is a simple example script that should do what you want
If( nrows(dt << get selected rows) == 0,
	dtx = new table("no rows");
	dtx << save("...........csv");
	stop();
